Genesis 2 Character Textures
in The Commons
Hi mates,
wich G2 characters have the best (almost photorealistic) diffuse skin textures?
You can link me to wichever character you think (DAZ originals or not, Renderosity, RuntimeDNA etc.)
Thanks.
moved to the Commons as it is not a product suggestion.
Frankly I think standard Bree can do well in that regard, you just have to set her up correctly. Just have the gamma correction set to 2.2 (if you are using 3Delight), make sure diffuse textures have a gamma of 2.2 and other images usually have a gamma of 1. I also generated some normal maps with a gimp plugin and I use the blood vessel textures that can be found for free on renderosity. Below is an Iray render of my setup, rendered in Iray. Otherwise you might want to check out http://www.most-digital-creations.com/ , his stuff is very photo-real. Especially if you want nudity in your renders. Still best do all that suff I mentioned anyway. Helps with subsurface effects.
Can remember Shifting Images' Domina blew me away with the skin quality:
http://www.daz3d.com/shifting-images
Of course, that was when 3Delight was the only option! I haven't attempted to render her with Iray to compare the basic visuals.
Thanks guys! I really appreciated :)
However my question, was not how to obtain a good render, but wich 2d diffuse maps image are very realistic.
Thanks again.
