Wind Wind textures not appearing in Iray rendering
Hello. I recently purchased the Wild Wind outfit via the DAZ store. Upon rendering the top and skirt appear bright white and not texturesa re appearing. However the 3D deight materials show up fine. I've tried doing some adjustments in the material settings and nothing seems to be working. Is this a problem with the product itself?
It sounds like there's a corrupt shader file -- go to the temp folder (you can find it by going to Edit > Preferences in DS) and delete the Brickyard subfolder. Then DS will recreate the shader files.
