How to change skin color of Face Transfer
Hey! I'm trying to create a 3D model of a real person using a picture with Face transfer 2, on genesis 9 base model. The picture is simple, I edited out the background so it's just the face on a white background. For some reason when using face transfer, the skin tone is off, way brighter than on the picture.
Is there a way to edit the Face Transfer once it's done? I tried editing the model with base color settings, but it doesn't render at all with IRay and shows up as a singular block of color with no shadows or texture.
Also is there a way to edit in a neck tattoo ? it is present in the original picture but doesn't show up in the transfer
Any help? thanks for reading!
  • It may be getting confused by the white background, have you tried using the base photo?
    The final base colour is the Base Colour value multiplied with the Base Colour map (in the Editor tab of Surfaces) so slightly darkening the Base colour will have the effect oif darkening the map - and if there is a slight colour cast you can also use a tint that is slightly lacking in the colour you want to eliminate to balance that.
