[solved] lantern iray glass shader mystery
bitwelderbitwelder Posts: 212
I'm making a lantern which uses a mesh/emitter for a flame and it has glass panes on 4 sides. When the lantern is placed at 0,0,0, it emits light as expected, evenly in all directions.  But if I just move the lantern along the ground in any direction, it stops emitting evenly.
Some things I've tried with no significant difference--although the quality of light may change slightly, the un-even emission pattern remains:
-- applied all the different glass and water shaders available under the iray presets
-- modeled the glass panes with thickness (6 polygons per pane), used single pane (1 polygon) glass, used double pane glass (2 polygons); also tried variations with normals flipped in different directions
-- turned "thin walled" option on and off in glass material surface settings
-- rotated the light/glass in the Y 90 degrees--- no difference, the pattern appears exactly the same--the pattern does not rotate with the light
-- removed the glass, and the problem was gone; it went back to even emission in all directions
For simplicity's sake I recreated the problem by making a primitive cube and applying the Iray "Glass - Solid- Clear" shader, then a sphere to which I applied Iray "emissive" material. I needed to tick "Two-sided light" to make the emitter work. Parented the sphere to the cube, and created a primitive plane for a ground. See results in attached jpeg. I'm using Daz Studio 4.8.0.59.
Any ideas what might be going on here? Why would just moving the lantern change the emission pattern? What are some more things I can try? Thanks!
Post edited by bitwelder on
  • FishtalesFishtales Posts: 6,216
    The shader for glass in a lantern is Glass- Thin - Clear. The Glass - Solid -Clear one is treated as a solid object and not a slim pane of glass so the whole of the inside of the lantern is treated as solid glass by the Iray renderer.
  • bitwelderbitwelder Posts: 212
    Thanks for the response. I tried applying Glass - Thin - Clear to the cube, but I'm still getting the irregular emission pattern...
    460 x 421 - 41K
  • SzarkSzark Posts: 10,634
    Did you turn ON Caustics in the Render settings Pane as I found that to be the key when lighting through glass.
    With Caustics turned on it is working great. Thanks very much, Pete!
    Sweet and my pleasure to help.
