Warning triangles at Morphs to export
BA-VISUALSBA-VISUALS Posts: 3
edited December 2024 in Daz Studio Discussion
Hi. I updated Bridge for C4D and also the plugin to the latest versions. When exporting any model with morphs, it shows me the names as you can see in the attached image. I have facial animation applied to the character, which worked for me when importing via Bridge in C4D, but now it doesn't work for me. I communicated with ChatGPT and tried the options, but to no avail. Do you have any ideas how to fix it?
  • The ctrl proerpties are certainly not morphs, theya re cotnrollers that drive other properties (uliotmately joints or morphs) and as such they will not export to FBX. The same may be true of the other warning properties. To the extent that that is correct you would, I suspect, need to bake down to actual morphs or transforms, rather than use the controllers.
  • crosswindcrosswind Posts: 10,281
    It always works... you should've exported the Pose Control properties you used from the path of Expressions in the list on the left of the Export Morphs dialogue.
    If you used Add Expressions function, it won't export any control properties that you used ~~
    Those " triangle " signs mean that those Properties have Sub-Compoments with ERC links to other properties... i.e. you need to check and export the dependent Morphs and Pose Control properties all together ~~
    Post edited by crosswind on
  • BA-VISUALSBA-VISUALS Posts: 3
    Thanks guys for answers.
    After exporting a figure with morphs from Daz and importing via bridge in C4D there is everything fine for manually controlling of joints. When I made a facial animation in DAZ and send it to C4D I only see moves of neck and head. No facial and eyes moves. I tried to export animation to FBX. It worked, but eyelashes and clothes do not move according to the body and face movements.
    This problem has started after updates of Daz and the bridge. I wrote on support, but I'm waiting for their answer for a few days. The problem is on Mac OS and Windows OS (default installations) and for all Genesis starter packs. I had not those triangels and white icons before.
    Is there a solution how to fix fast? Your answers are complicated for me.
    Post edited by BA-VISUALS on
  • Same problem for me, warning all appear with the updates, don't find a solution yet
