How to set 3D's MAX material & render from imported DAZ
Hello!
Anyone knows?
How to set 3D's MAX material & render from imported DAZ chara settings?
I wanna get same result of DAZ rendered.
Thanks.
Hello!
Anyone knows?
Thanks.
You can't without manually doing it. They don't use the same render engines. And from what I gather (but could be wrong) even the Iray implementations are no where related when it comes to material nodes.
So just like most unrelated 3D packages, when you render in one, it won't render the same in the other. (unless there is a magic Iray converter/transfer tool from Daz to 3DS which I missed).
Hi larsmidnatt!
Thanks for your reply. Only manually & test it....
In my project, 3D characters are made by some 3D software. And finally, they will set material and rendered on 3D's Max(Also Motionbuilder).
Iray is existing on Max. First, I'll try those settings.
