Bryce Freebies - Bunyip02 Blender models
https://www.renderosity.com/freestuff/items/99095/bryce-castle-1
https://www.renderosity.com/freestuff/items/99096/bryce-dungeon-bunyip02-updated
https://www.renderosity.com/freestuff/items/99097/bryce-planet-1
https://www.renderosity.com/freestuff/items/99101/bryce-poly-trex
Post edited by Bunyip02 on
https://www.renderosity.com/freestuff/items/99102/bryce-spaceship3-greebled
https://www.renderosity.com/freestuff/items/99103/bryce-spaceships-1-4
https://www.renderosity.com/freestuff/items/99108/bryce-well-1-bunyip02
https://www.renderosity.com/freestuff/items/99110/bryce7-update-space-station-1b
https://www.renderosity.com/freestuff/items/99111/bryce-ray-gun
https://www.renderosity.com/freestuff/items/99122/bryce-retro-rocket
https://www.renderosity.com/freestuff/items/99123/bryce-scificrate
https://www.renderosity.com/freestuff/items/99124/bryce-snowman-1
https://www.renderosity.com/freestuff/items/99129/bryce-toon-cabin
Thank you for the limk to your Freebies, Bunyip02.
Thank you so much for the freebies, I just wonder how to import them in Daz Studio.
Regards,
Rosselani
Thanks for the freebies Bunyip02
There is a lovely Bryce community for doing Bryce renders - but if you insist on DAZ Studio being your preferred workspace there is an export out of Bryce that you can do.
Click on File, choose Export Object
There are a number of export formats to choose from.
You can also export Terrains
Increase Grid Triangulation (not too much or it will crash), choose Size, choose Format, hit the tick button.
Have exported objects to Carrara, but also spend time in Bryce doing renders - have fun !
I just finished Bryce 7 Pro installation.
Thank you again!
Thank you Bunyip, you've been busy.
I used the castle freebie in two renders. In one I added a ship (Black Pearl from Renderosity) and a distant terrain. The sky is from fantastic skies. In the second one I added a low poly figure and a low poly ostrich, a couple of ecotrees from the Vegetation set and one low bush from the same set instanced many times. Sky is from Judy K.
Hansmar - Beautiful renders, glad you are getting use of the freebies !
