I can't find my Reality plug-in
Luv Lee
in The Commons
I bought Reality today and tried to download it...it has an automatic .exe file for windows so it installed compents as soon as I clicked download--but when I open up DAZ I can't find it anywhere. I looked in the plug in section and its not there either. I closed DAZ. Re-opend it. Still no Reality. I shut down my compueter compeltely, Restarted. Opended DAZ. Nothing. I have no idea where the plug in is or why it appears it won't install...
It should have downloaded whats is known as a "self extracting installer", Which is a bit confusing, because it doesn't actually install anything :)
after it downloads, you click it,,, it unzips itself and makes a folder called "Reality_DS_w64".
in that folder will be a bunch of files.One will be the actuall installer, called "RealityInstaller.exe" . There should also be a PDF called "Installation.pdf" that has more specific instructions in case you had an earlier version of Reality installed that needs to be delt with first.
hope this helps :)
addendum--after alot of diggign and searching I was able to locate the install.exe, the installation info and the area where Reality was in DAZ...thnaks in advance for those who would have lent a hand. :-)
