Searching for hair...
yagakisan
Hi all, I'm searching for these two characters hair (main promo images):
https://www.daz3d.com/ly-ashlyn-hd
Thank you!
Post edited by Chohole on
yagakisan
Thank you!
fixed your first link for you, as it was giving a 404 and moving your thread to the Commons, as it isn't a product suggestion.
Hi,
I think the hair for LY Ashlyn is the Dove hair, which can be found at http://www.daz3d.com/dove-hair-for-genesis-3-female-s. Not sure about the hair for Luna.
Edit: The one that might be the closest in the Daz store for Luna can be found at http://www.daz3d.com/dye-4-nyoko-short-hair.
Hope that helps.
The Luna promo is an old one. So the hair used is one of the old ones in the store here. Definitely V4 era, possibly V3.
The store no longer lets you search by product categories (genre is not category) but Actual Hair by Mindvision looks pretty close. The texture set is probably from the Toxic add-on if that is the hair used. But it could be a different but similar hair.
Thats not Nyoko hair on Luna unless you loaded it more then once to give that fuller look.
The Luna hair may be "Wild Hair" by DigiCalimero, an old one that used to be sold at Renderosity. I have it, it's pretty good, though the trans maps can make it look a bit thin depending on the lighting.
https://www.renderosity.com/mod/bcs/wildhair/63448
Could also be the now unfindable Moni Hair, but I think it's the Wild Hair
Thank you all!
Another search... :)
http://www.contentparadise.com/sellers/syltermermaid/images/lrg/Crimson01.jpg
Does anyone knows which hair are these?
That hair is Red Roses Hair at Rendo
https://www.renderosity.com/mod/bcs/?ViewProduct=102894
Thank you so much!
