Post denoiser not working
The post denoiser isn't working in some renders and I have no idea why.
  • Have they dropped to CPU? The denoiser requires the GPU be active.
  • FantastArtFantastArt Posts: 419
    I don't know, I didn't change anything. How can I check it?
  • Check the log file after rendering, it will tell you what was used.
  • WhiteFoxWhiteFox Posts: 94
    edited September 2025
    I came here looking for an answer for the very same issue. I recently had to do a factory reset a few days ago, and today I noticed after getting everything installed my denoiser wasn't working.
    Info: MSI Titan 18 Laptop with Nvidia 4096 RTX. Windows 11Pro.
    I discovered that doing a 'Repair' in Windows 11 'Apps' fixed the problem.
    Steps I used: Open 'All settings' in Windows 11, go to Apps/Installed Apps, and select AV1 Video Extention, click in the 3 dots and select 'Advanced Options' scroll down to 'Rest' and click on 'Repair'.
    Hope this helps someone.
    Post edited by WhiteFox on
  • crosswindcrosswind Posts: 10,285
    Does it have anything to do with Post Denoiser in DS > Render Settings ?
     Not that I'm aware of. I just know that as soon as I did that the Daz Studio viewport immediately cleared up and my renders were running right.
