Antler Headdress
Is there anyway to remove/hide the roses in the Antler Headress ? I've seen other pictures in the gallery without the flowers.When I look at it in the scene tree theres no part for the roses :/
  • MelanieLMelanieL Posts: 7,761
    They may be a separate material zone - look in the Surfaces tab and see if the roses are listed there. If so, you could set them to be transparent.
  • felisfelis Posts: 5,959
    I don't have it.
    Looking in the file list there is not an option default.
    But I would  assume that is has its own surfaces (else would the flakes option be more complicated) and then you can set Cutout Oppacity to 0, which will make them invisible.
    Last option is to create a graft using the geometry editor, and then you can switch them off, but that might require some work you are not so comfortable with.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,297
    edited August 2025
    wow that's pretty
    never noticed it before and 60% off, wishlisted but considering just buying now
  • laurieannlaurieann Posts: 10
    edited August 2025
    Thanks all,Ill try looking in the sufaces tab :)
    That worked thanks :)
    Post edited by laurieann on
