Wow that is some patch ... dForce SU Medium Length Jeans
hjakehjake Posts: 1,312
dForce SU Medium Length Jeans for Genesis 9, 8.1, and 8 Female
https://www.daz3d.com/dforce-su-medium-length-jeans-for-genesis-9-81-and-8-female
Can the Sue Yee patch be hidden?
  • I'm sure it could be retextured fairly easily.
  • hjakehjake Posts: 1,312
    So the buyer's only options are to either alter the texture or purchase the texture pack? Wow that is some patch! laugh
    https://www.daz3d.com/expanded-textures-for-dforce-su-medium-length-jeans
  • Might be a separate layer in the material section that you could amend its opacity to 0.  Hard to say without buying it.
  • crosswindcrosswind Posts: 9,715
    Yes, but there'll be a "shape of patch" left ~~ especially with the light color textures.
    2560 x 1392 - 2M
    1424 x 1294 - 1M
  • BejaymacBejaymac Posts: 1,968
    Going by the mesh view (last image) it looks like it's modelled into the mesh.
    edited August 2025
    I just noticed even in the texture expansion show the patch locations. So I would agree that the patches outlines are modeled into the mesh.
    Thanks everyone for your replies. I will have to pass on this product.
    482 x 732 - 50K
    Post edited by hjake on
  • This would probably be short work with the Smooth Brush in Blender, for those who are inclined.
  • I was interested in those, until I saw that patch. Now, reading this thread, I'm going to pss on it
    edited August 2025
    Ah, I'm sorry but you don't have to really pass on it. There's another good solution to hide it but show no mesh of the brand patch... by using Conditional Graft.  I made them on both of jeans for G8/G9 as well as a smoothing morph... in case you're willing to buy it.
    If you have the products then, you can extract the data folder within the attached ZIP file to the root directory of your Daz Library where you install the products.
    Then load the jeans and dial the property Hide Brand Patch when you want to hide it.  Crank up Smooth Brand Mesh if you want it even more smoother.
    Hope the solution helps ~~
    2560 x 1392 - 2M
    2560 x 1392 - 2M
    zip
    zip
    Hide Brand Patch.zip
    415K
    Post edited by crosswind on
  • ElorElor Posts: 3,530
    edited August 2025
    I also found that the patch felt a bit too big, but with the solution from @crosswind (thank you, I saved it for a later use), the overall look of the jeans are nice.
    I'm not in a spending mood currently, so it's only wishlisted but it's nice to see a median length pants from Sue Yee, who until now mainly had either short pants or longer ones.
    Post edited by Elor on
    edited August 2025
    That is incredibly generous. Thank you for taking the time to do thatsmiley
    You're welcome ! laugh
  • barbultbarbult Posts: 26,524
    Your skills are impressive.
  • xyer0xyer0 Posts: 6,399
    crosswind to the rescue! I don't even like shorts/not-shorts, but I may get these just because of this fix.
    Thank you guys ! Enjoy the product !
