Full Screen Mode
Hi,
I am running win 7 with the latest DAZ3D 4.8 and when I go into fuill screen mode I can not exit by escape.
Searched everywhere with no solution?
Thanks
Hi,
Thanks
Shift F11 works as a toggle for me.
Thanks but does not work for me?
In 4.8.0.59?
Wahoo, works for me at any rate! That is really cool, thnx.
press F3 to open the Window settings menu.Or click Window > Workspace > Customize
Scroll down to "Window" on the left side of the pane
Exapnd that and look for "Full Screen Mode"
If there isn't a keyboard shortcut set already you can change it by right clicking it and selecting "Clear Keyboard Shortcut" Then right click again and select "Change Keyboard shorcut", it will then ask you to press the button you want to use for the shortcut.Press "Apply" then press "Accept".
thank you all
