Smart Spot Render installation help
Hello all,
I just bought Smart Spot Render and I cannot seem to figure out how to get it working. Auto-install through DAZ DIM doesn't seem to be working for me as SSR doesn't appear in the tool settings tab in either the 4.24 or the alpha build. Any help is appreciated.
  • crosswindcrosswind Posts: 9,708
    You need to go to: Help > About Installed plugins..., paste the serial number as reauired. Close and relaunch DS, you'll find it under Tools.
    Be noted, this plugin only works for DS 4.x by now rather than DS 6.x ALPHA.
    669 x 868 - 76K
    Thank you. Didn't realize I had to do that.
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log_4_24_0_3#4_23_1_44 I haven't been able to see this in action as all my plug-ins are registered, but if you are logged in DS can now retrieve serials and allow you to select them instead of having to use copy/paste.
    I've not checked change log for a while. Sounds a nice new feature...will try it next time. TY!
  • nouse84nouse84 Posts: 6
    Will this get updated to work in DS 6.X ? would it be better to return it now just in case?
