eye shadows too dark
is there a way to not have these hard shadows on iray with a distant light, without having to add spotlights or whatever?
  • A distant light is harsh, and unrealistic (there is usually light scattering from the environment etc.)
    and what can i do to fix it other than putting spotlights, its the same with sun sky
  • alkenalken Posts: 270
    edited August 2025
    With the sun-sky, you can soften the shadows by increasing the sun disk scale to 10 or higher.  You may need to increase the sun disk intensity after you soften the shadows.
    If you use a distant light instead, you can't soften the shadows, but you can lighten them by using a light colored HDRI.
    Post edited by alken on
