3DU Noodles, no poses in d/l?
Mistara
in The Commons
http://www.daz3d.com/noodle-the-toon-cat
i'se not seeing a pose folder of poses for Noodles. There is a bunch of poses in the promos.
was it left out by accident?
Thanks.
No user-facing files. The poses are morphs and are done using sliders in parameters. Very flexible this way because you can slide from one position to another and stop anywhere in between, then slide another one a little bit. Brill.
thanks. found the sliders.
can also select body parts to rotate.
not as expected, but it works, :)
Thanks that anwsered two question at once thanks again!
