Adventurer's Toybox - Karesh Kit (Just Released.)
RaneRane Posts: 151
edited August 2025 in Daz PA Commercial Products
We here at Haille Valley are so very busy.  So much so, we decided to add to our load and create a pair of robotic auxiliary limbs!  We found them so very useful, we decided to offer them to you, our customers!  As such, we have a few particularly wonderful and UNIVERSAL objects for you to enjoy.
An Auxiliary limb set, with pseudo-standard tail socket.  These are usually mounted to the exterior of the hips, along the spine, but can be mounted anywhere.  These are universal, as anyone can use them.
A Jetpack, with two articulated thruster nozzles on the bottom, multiple RCS thruster nozzles on the exterior, and two auxiliary thrusters for additional lift.  This is a universal pack, and can be mounted on anyone.
An Auxiliary limb-thruster set, with pseudo-standard tail socket.  This set is a modification of the Aux Limb set, where instead of hands, there are a pair of heavy-duty engines.  These are designed and intended for the wearer to fly in atmo or Zero G.  However, they are clunky and awkward when not powered.
A tail and stand-alone standard tail socket.  This set attaches to the outside of your clothing, and well... mounts the tail to you.  The tail itself is cybernetic, with overlapping and interlinking plates, with a spade tail tip and tail spike for self-defense.
We hope that you, the user, will take yourself and your capabilities to the Edge of Space and Beyond.
(Please note that while Genesis 9 is the default figure used, this can still be used as a universal parented prop. You simply place it in the figure hierarchy to make it stick.)
Post edited by Rane on
