Trying to identify a spacecraft
nabob21nabob21 Posts: 1,057
Hello,
Can anyone help me identify the spacecraft/escape pod that is used in the promo image from KindredArts Jurassic FX?
https://www.daz3d.com/jurassic-fx
Thanks in advance for any replies.
nabob21
  • NorthOf45NorthOf45 Posts: 5,729
    It is a part of a much larger set: XI Exo Suit Hanger. Unfortunately, none of the promo shots show the pod by itself. It doesn't have a hatch, actually, which is rather odd for the vacuum of space.
    400 x 395 - 60K
  • nabob21nabob21 Posts: 1,057
    Thanks Northof45. Sucks about having no hatch, though.
  • ShimrianShimrian Posts: 585
    While not quite the same, both of these escape pod type spacecraft have hatches:
    https://www.daz3d.com/explorer-pod
    https://www.daz3d.com/nomad-module-2
  • You could create a 5cm long cylinder primitive of the right diameter, pivot it at the extreme top and apply a glass shader. That way it could work for you as a closure with little or no modelling.
  • markusmaternmarkusmatern Posts: 605
    edited August 2025
    There is somehow a hatch, but in a different part of the set in a sub part, that is not its own prop, but its's own object:XI EH EscapePod Room.
    You would need to tinker with the geometry editor to extract it. You can see the whole setup in the second promo image https://www.daz3d.com/xi-exo-suit-hanger :
    This is what I came up with, after deleting the unneeded geometry, then scaling the hatch and moving it into position. The opening is not round, but oval. And I deleted the hinge mechanism.
    1024 x 1024 - 117K
    Post edited by markusmatern on
    How did I miss this one? EEP - Emergency Evacuation Pod is a decent substitute. Only found it (again, wishlisted almost 6 months ago and since forgotten) because the PA has a new release (Digivault Productions, formerly The Digivault)
  • LeatherGryphonLeatherGryphon Posts: 12,176
    Perhaps it uses a flat forcefield instead of a hatch.  Similar to what is used in the shuttlebay on starship Enterprise.enlightened indecision
  • jjoynerjjoyner Posts: 766
    Another alternative vehicle could be the Steampunk Time Machinehttps://www.daz3d.com/steampunk-time-machine​ .
    Thanks everyone for all the help.
