[Released] MD Setup Figure's Morphs Controllers [Commercial]
MikeDMikeD Posts: 317
If you're a character creator looking to set up custom morph controllers for your figure easily, this script is made for you.
'Setup Figure's Morphs Multiplication' is a tool that allows you to link your custom morphs with a base figure morph using one of three modes, ensuring the correct activation and behavior of your morphs.
The linked video demonstrates the script.
Post edited by MikeD on
  • ArtiniArtini Posts: 10,541
    Is it only for Genesis 9 or could work for other figures?
  • MikeDMikeD Posts: 317
    For any Genesis Figure
  • Any plan to add multiaxis support? Or to make it process multiple morphs at once? Or any further development?
    At the moment I don't see it doing much for me that I can't do just as quickly manually tbh. The basic links and muiltipliers it does do are the simpler ones to set up. At least with the Property Heirarchy tab I can see everything in one place This is useful for some things, but it doesn't do others so I'd be chopping and changing between workflows.
    Now of you could make it easily set up multiaxis links....
