Carrara GPU Use
Steve K
From Google Chrome AI: "Carrara, a 3D modeling and animation software, utilizes the GPU for rendering its scenes, particularly for display lists. While it uses older OpenGL display list technology, it leverages the GPU's capabilities effectively, especially for static geometry. However, Carrara's GPU usage is less efficient when editing meshes, as this process requires more CPU interaction."
I thought Carrara only used the GPU for animation previews, using OpenGL. But this sounds like more than that.
I am considering a new computer, and have been looking at the mini PC's at under $500. The specs look pretty good, fast AMD CPU's, etc. Many have AMD Radeon graphics which are "integrated" but get good reviews. Will Carrara use these? Any general comments on these mini PC's?
I am very dubious about that - as I've said before, do not trust the computer, the computer is not your friend.
But those mini PC's are getting some good reviews ...
no, Carrara only uses the CPU for render
however it definitely uses the GPU for the viewport but it doesn't need to be Nvidia as OpenGL and only reasonably OK
not a potato like my old Dell inspiron Craptop was or for that matter my onboard graphics on my Win7,
about 2GB VRAM is fine, anything less it (the viewport) will struggle
will still render fine though
OK, thanks. That's pretty much what I recall hearing long ago.
