We Now Have "Already Owned" Tags
2»
  • joannajoanna Posts: 2,775
    jjoyner said:
    paulawp (marahzen) said:
    Following up to note my test of this so far. Initially I picked up one of these completed bundles, a small bundle that had three products which I bought separately, only to find that they were missing a necessary core item (the Safe House bundle). I was able to get the Safe House bundle for free, since I own all three items under it. On my Product Library, it only shows the items once. That's good news if you're concerned about duplicates, bad news if you use it to keep track of when you originally bought the items since they now only show on the new order.
    As noted, I don't use DIM. I had no issue installing the missing "Safe House" core item I needed, and the existing items were clearly already installed.
    @paulawp,
    Does the Safe House (https://www.daz3d.com/the-safe-house) have a back wall?  All of the promo pictures seem to have been taken looking from the back towards the front and one promo picture shows the room without a back wall.  It could be that the back wall was hidden, but if not, not having a back wall limits the camera angles one can use.  Thanks.
    I'm not @paulawp, but from quick opening both preset scenes (full scene and just the building) and rotating the camera, all the walls are there.
  • ElorElor Posts: 4,120
    jjoyner said:
    @paulawp,
    May I introduce you to your futur best pal for crawling in tight spaces, the Iray Section Plane Node ?
    You can create them manually:
    https://www.deviantart.com/slimmckenzie/journal/Tutorial-Iray-Section-Plane-Node-beginner-661286658
    You can also see it in action in the promo renders of Camera Cutaway (which provide script to create them):
    https://www.daz3d.com/camera-cutaway
    or the Victorian bathroom (which include one)
    https://www.daz3d.com/victorian-bathroom-vignette
  • jjoynerjjoyner Posts: 850
    @Elor,
    Thanks.  I am lightly familiar with section planes.  I have explored them a little bit and have watched a few videos about them.
    @joanna,
    Thanks much for researching the product for me!
