(SOLVED) Rigid Follow Node - Child flies away when morph dials used
Joe827Joe827 Posts: 272
I'm trying to use a rigid follow node to make an eyebrow ring move with a character's facial morphs.  I'm using V4 as the figure and a torus as an eyebrow ring.  I've attached images that show the selected polygons used for the follower, the follower location in the scene tab with the Torus, and a gif that shows what happens when I adjust an eyebrow morph.  As you can see, the torus moves forward and backward far away from the figure when the morph dial is manipulated instead of moving up and down with the eyebrow.  I've done this before for nipple and navel piercings and had no problem.
Any hints?  I've already tried increasing the number of slected polygons for the follower, but that gave me the same results, and I've also double checked my work against this YouTube tutorial.  Thank you.
Update: I am using Daz 4.24.0.3
Post edited by Joe827 on
  • felisfelis Posts: 6,507
    Can you show an image with the rigid follower visible on the character? It is 3 lines collered in the base orientation colors.
  • Joe827Joe827 Posts: 272
    Good hint!  For some reason, it added the follower waaaay up there.  When I manually move it to the location of the selected polygons, it works as expected.  For fun, I just tried creating a few more, and all of them end up above the character's head.  I am using Daz 4.24.0.3.
    660 x 886 - 77K
    It use just to be lines, but if that is the rigid follower node, then it is no surprise that your piercing is acting weird.
    What is your process for creating it?
    1) Select one or more ploygons using geometry editor
    2) Right click, Geometry Assignment, Create rigid follow node from selected
    920 x 899 - 466K
    Weird, there should come a cross around the selected polygons.
    I don't know if there is something weird with the old characters. Could you tried on a G8 or G9 just to verify?
    It appears at the expected location on Genesis 8.
    713 x 741 - 156K
  • crosswindcrosswind Posts: 10,257
    edited July 2025
    V4 is different... RFN is created with a wrong value esp. on its Y Translate as well as Y Translate Delta. That was why you found the RFN high up there above the figure.
    If you select RFN, turn on Show Hidden Properties... in Parameters pane, you'll find both values. You can use Y Translate minus Y Translate Delta, RFN will be back to its correct position. Just do the same to X Translate and Z Translate as well.
    Post edited by crosswind on
    Got it.  Thank you both.
