Beaching of Hair and Fur
On a few products I seem to have an issue where the hair comes out with no color.  Does not happen with every hair and just wondering if it is a setting?  It could also be an issue with my PC as I did lose my external HD and had to reload a great amount of protuct.  Examples are Faustian Fringe Hair and Armor of Savage Fury.  Thanks for any help.
  • felisfelis Posts: 5,970
    Which version of Daz Studio are you using?
  • TraceSLTraceSL Posts: 544
    4.22.1 Pro 64 bit
    I thought it might be a case of missing Omnihair shader. If you serach in shaders do you then have a 'Omnihair Root Tip Blend) shader (part of default ressources)?
    If you go to the Surface tab for the hair (you might have to expend it in the scene tab from the cap to the hair), which shader is then listed?
    Thought something was missing too but noticed it seemed to be just dForce hair but then noticed the armor.
  • Richard HaseltineRichard Haseltine Posts: 108,695
    Make sure you have the current version of the Default Resources package.
    I also saw a protuct picture that had some greyish hair that looks like the same problem.  See DAV Jenda
    Resourses were installs BUT all links to products were broken, re-installed package but no change.  As it is only a limited number of products and new ones (G9) starting to feel is is the age of my PC.
  • Seven193Seven193 Posts: 1,146
    Does the hair use hierarchical materials?  If you use AutoFit on such hair, materials will no longer work. You should look at your Daz error log when applying the material, as it shows up as an error there too.
    Did you just reinstall from the existing download (assuming you had one) or did you do a fresh download, or install diect from the servers with Connect?
    Did a uninstall, closed DAZ, restarted DAZ and the did the download from Connect.
    Nothing in log.
