Animation time line, insert time
Is there any way to insert a dozen frames between frames X and X+1? Seems like the kind of thing that should be a standard function of an animation tool.
  • crosswindcrosswind Posts: 9,749
    I assume you mean Keyframe(s) rather than frame(s) ...It can be easily done by Drag 'n Drop... to Move Keys:
    Click to select Keyframe pointer at X+1, or marquee-select it (drag a frame to select it...), or marquee-select multiple Keyframes if there're any after X+1, then drag forward (to the right...) so as to "insert frames" that you need.
  • jmucchiellojmucchiello Posts: 980
    I had no idea you could marquee select in the timeline.
    Why doesn't undo restore a deleted key?
    Delete Keys can be undone ~
    You select a Keyframe, Delete Key, then Ctrl + Z, the keyframe is not restored ?
