Discolored figures after using New Genitals for G9 software package
omvendtomvendt Posts: 120
edited July 2025 in New Users
Dear all, I am new here and wanted to share a problem and a solution in case other nitwits like me struggle up the learning curve.
I used NGG
[Link  removed]
to tune the undercarriage of a model. Looked great and then suddenly it didn't. My heroine looked like she had gangrene. After much frustration, I realized that this happened because I had Mesh Grabber active. When I switched away, the problem was solved.
(O:
  • felisfelis Posts: 6,105
    It looks more as if you have a breast geograft.
  • LeanaLeana Posts: 12,948
    Having a breast geograft would explain that region looking weird when geometry editor tool is active: both the original mesh and the geograft are displayed in that case, as geometry editor would be used to select the polygons from the original mesh you want to replace by the geograft.
