Anilip3 crashes Dazstudio 4.24.03.
Using Windows 10 with a supported graphcs card running Daz Studio 4.24.0.03 with Max genesis 9 figure. Every time I try to use TTS with a supported WAV file I get this error. "DAZStudio.exe caused ILLEGAL_INSTRUCTION in module "C:\Program Files\DAZ 3D\DAZStudio4\dbtScreenplayDialogLib.dll" at 0033:00000000F972BAD7, cDbtTokenizer::makeWordList()+534663 byte(s)" No matter what I try TTS or STT it does the samw and when I click on the close button Daz Studio exits. If it cannot be resolved then it is absolutely useless to me. If anybody can help mr I would appreciate it. I submitted a ticket but haven't heard back yet.
  • Richard HaseltineRichard Haseltine Posts: 109,102
    Acording to your crash log you have an AMD FX 8150 - that seems to be a CPU from 2011 or thereabouts. The crash itself says Illegal instruction so my suspicion would be it is a CPU issue, the dll in question may nbeed something added to the AMD 64 instruction set after that CPU was released.
  • preetcherpreetcher Posts: 2
    Thank you so much for your reply. What can I do to remedy that if anything?
    If it is the CPU instruction set then nothing short of a CPU upgrade/new system, I fear - but although the information is suggestive I would not take it as definitive
    Do you have any idea what I would need to upgrade to? Thanks for your help. I really aooreciate it.
    If it is a missing instruction set then you would need a new enough CPU to support that instruction set - but I cannot immediately se any fine-grained system requirements that would tell which instruction sets are required.
  • DobitDobit Posts: 207
    Anilip3 requires Windows 11 to work properly.. This requirement is mentioned in the shop.
