Weird alien head ridge
IceDragonArt
This is the second time this has happened. Last time the only way I was able to get rid of it was to completely uninstall daz and re install. NOT willing to do this again. I have far too much content on here to try and remember where all the freebies that I have loaded came from. Not to mention the hours and hours of time tracking them down. I have checked every single morph and they are all set to zero.
over in the "Show us your iray renders" thread L'ADiar made a post about this.
http://www.daz3d.com/forums/discussion/57355/show-us-your-iray-renders-part-iv/p84
Here is the part I think you'll want.Probably might want to read the whole thing though ;)
Thank you! I did find a button at the top left right next to the parameter, posing shaping that said remove all presets or return to original or something like that, that seems to have fixed the problem. Going to go read up though cause when it happens it drives me nuts.
You're welcome,,
btw,,if you find the button you pushed to fix this,,could you post it :) some of us have had the same problem and couldn't figure it out .
I will. but I am not sure if pushing that button is what lost all of my poser files so I am going to advize caution. Haven't figured out what caused it but its the only thing I did that was different than normal.
