Fabiana Appreciation Thread
13»
  • FabianaFabiana Posts: 258
    SilverGirl said:
    Write Idea said:
    I have this rather large SciFi project I'm putting together. I'm doing all the characters and even making the clothing. I knew the silhouettes I was going to use for the garments, but had no idea what shaders to use. I looked all over DAZ to find the right shaders, but nothing worked. Everything was just so busy and loud. I love clean, sophisticated, and simple.
    I've had Fabiana's clothing shaders from Renderosity for years, and they just look perfect! It's like Chanel is space. Understated, polished, and elegant.
    Thank you as always, Fabiana!
    +1... Fabiana's shaders are absolutely my go-to when I want cloth to look fantastic!
    Thank you!!!!!!!!!!!!!
  • xyer0xyer0 Posts: 6,374
    Fabiana said:
    Elor said:
    I understand it's a custom flooring and that it's not included but does someone has some tips and advices on how Fabiana got the floor to look like this in the following render for Theory of Light 2 - Energy Flow, the one with the man sitting on the floor:
    Hi @elor
    That was a very custom setup, I remember it. Based on my floor settings from the Shader Plan or the Theory of Light itself, I added a bump map and probably used it for the texture too. Hope this helps!
    I have NEVER seen Gianni 7 look this good!
  • ElorElor Posts: 3,441
    Fabiana said:
    Hi @elor
    Thank you: I'll experiment following your advices the next time I'm trying to render something with it and see how it goes.
    Speaking of rendering, one I did recently with your fabulous umbrella catching the light smiley
    Hello! I've been off due some health troubles but a friend reminded me to come and post that I have an Instagram account for all those that could want to follow me there. It's @fabiana3d Feel free and welcome to follow me there. Cheers!
  • SilverGirlSilverGirl Posts: 3,220
    Very sorry for your health troubles, and hope you are much improved (and continuing on the upward swing, if such is applicable)!
    If I Instagrammed at all I would absolutely follow you, but hopefully you get a boatload of other subscribers!
