You Have Face Transfer, How About Prop Transfer
You need a prop that's not available but you see what you need in an image. You are able to create a figure via Face Transfer, so why not also have a Prop Transfer or even a Environment Creator for photos of places you would like to create.
  • Seven193Seven193 Posts: 1,147
    You mean image to 3D?  That's a AI thing.  If you do a Google search on it, there are some AI services you can sign up and use it to create 3D props from images or text.  But, don't expect to get stunning, high quality results from it.  More likely, you'll get something that looks like it was created from a 3D scanner.  Lots of triangles, horrible edges.  But, maybe you could clean it up with some remeshing.
  • GordigGordig Posts: 10,678
    Face Transfer copies a photographed human face onto a 3D human face. Anything beyond that, like turning a photo of a room into a 3D set, is a much, much bigger ask.
  • memcneil70memcneil70 Posts: 5,678
    edited July 2025
    I looked at your request a few days ago and drew a blank, but with @Gordig's comment something triggered in my mind. This isn't for a prop, but an enviroment and creating your own HDRIs by V3Digitimes, https://www.daz3d.com/v3d-hdr-master-bundle. It won't let you duplicate another's creation into a 3D prop but if you built an environment with items you bought, modified as needed with shaders, you might have something you can use.
    Post edited by memcneil70 on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,613
    edited July 2025
    Meshy3D      Tripo3D     Hunyuan3D
  • richardandtracyrichardandtracy Posts: 7,515
    I've seen Meshy3D, and some of the output looks really good. Right up to the point of looking closely. Then it rather falls apart. Maybe in the nearish future it'll be better. Regards, Richard
