Axis Symbols appearing on props and models
Has anyone had this issue? As of late, some of my props and models have been getting the axis on them. Like I won't have it selected and it would look like the object or model is selected to move it. Is this a bug on DazStudio or is it the object or model?
  • felisfelis Posts: 6,081
    It looks like rigid follower nodes.
    Have you attached anything to the character?
  • Richard HaseltineRichard Haseltine Posts: 109,174
    Which tool is active (Tools menu)?
  • crosswindcrosswind Posts: 9,704
    It could be a Group node, a Null, a rigid follow node...
    You can check the objects in Scene pane, Expand All, see if there's any above-mentioned object. Specifically check objects under Neck bone.
