[Solved] New PC - DS not installing error ?
2»
  • Richard HaseltineRichard Haseltine Posts: 109,552
    Daz Central and DIM are essentially the same under the hood, and if installed after DIM Daz Central will adopt its settings and vice versa so I am not sure why one would work when the other didn't, other than possible security software issues.
  • franky85franky85 Posts: 153
    neeshka said:
    I had this issue with another computer and installing Daz Central fixed the download issues with DIM. https://www.daz3d.com/downloader/index/dazcentral
    Sorry for the thread necromancy but thank you! I just installed DIM on a new laptop with a clean install of Windows and it would fail with the same SSL errors, even after installing the godaddy certificate mentionned previously in this thread.
    2026-01-26 22:16:17.297 [INFO] :: Requesting: 18869-2 : PostgreSQL CMS (Win 64-bit)
    2026-01-26 22:16:17.297 [VERBOSE] :: Checking session ID validity...
    2026-01-26 22:16:17.384 [VERBOSE] :: Session ID valid
    2026-01-26 22:16:17.384 [INFO] :: Requesting: 13176-2 : DAZ Studio 4.24 (Win 64-bit)
    2026-01-26 22:16:17.384 [VERBOSE] :: Checking session ID validity...
    2026-01-26 22:16:17.462 [WARNING] :: SSL Error: Unable To Get Local Issuer Certificate - The issuer certificate of a locally looked up certificate could not be found : Certificate is valid
    2026-01-26 22:16:17.462 [WARNING] :: Network Error: 0 -  : SSL handshake failed
    2026-01-26 22:16:17.494 [VERBOSE] :: Session ID valid
    2026-01-26 22:16:17.494 [INFO] :: Requesting: 13176-42 : Default Resources for DAZ Studio 4.23+
    2026-01-26 22:16:17.494 [VERBOSE] :: Checking session ID validity...
    2026-01-26 22:16:17.556 [WARNING] :: SSL Error: Unable To Get Local Issuer Certificate - The issuer certificate of a locally looked up certificate could not be found : Certificate is valid
    2026-01-26 22:16:17.556 [WARNING] :: Network Error: 0 -  : SSL handshake failed
    2026-01-26 22:16:17.627 [VERBOSE] :: Session ID valid
    2026-01-26 22:16:17.627 [INFO] :: Requesting: 13176-44 : Default Templates for DAZ Studio 4.23+
    2026-01-26 22:16:17.627 [VERBOSE] :: Checking session ID validity...
    2026-01-26 22:16:17.703 [WARNING] :: SSL Error: Unable To Get Local Issuer Certificate - The issuer certificate of a locally looked up certificate could not be found : Certificate is valid
    2026-01-26 22:16:17.703 [WARNING] :: Network Error: 0 -  : SSL handshake failed
    2026-01-26 22:16:17.734 [VERBOSE] :: Session ID valid
    etc...
    However, installing DazCentral (deprecated, I know!) fixed DIM..! It also continues working after uninstalling DazCentral.
