Any suggestion for water /sweat dripping on skin
in The Commons
Hey Guys,
I want to create a water dripping or sweat dripping from the figure, I tried using Ultimate Skin Moisture but this has a lot of water droplets all over the skin I dont want that. I want just a single or couple of water drips. Is their any products or way to do this in DAZ?
Thanks in Advance.
One possible way could be to create a geoshell of the character, use a water texture on it then apply a transmap?
@V3Digitimes is selling a drops generator which feels like a great if not the perfect match for what you want to do:
https://www.daz3d.com/drops-generator
Support thread: https://www.daz3d.com/forums/discussion/comment/8941541/
It's a set of scripts that will allow you to place droplets over a surface, by selecting the part of geometry where you want them and it also offer the possibility to place drips, including rigged ones to closely follow a surface shapes (the non-rigged drips are perfect for straight surface like a window, a can of soda).
On this render, I used it to add the droplets on the swimsuit, and placed four drips: one one her arm, two on her swimsuit, and one starting on her swimsuit and ending on her tight.
You can only (barely) see droplets falling from her lower leg, made by using a invisible primitive plane and selecting only droplets that looked like they were falling (off the top of my head, you can add your own droplets if you have some modelled).
As with all her products, there is a lenghty manual explaining the nook and cranny of Drops Generator, and you can ask question in the support thread if you have some before buying it (or after too).
Gallery link if you want to know the other products used: https://www.daz3d.com/gallery/user/6244146477531136#gallery=newest&page=1&image=1354945
Wow thank you that is what I was looking for. Its perfect.
i like this a lot. Did you use another product for the overall wet look?
Yes, another one by V3Digitimes:
https://www.daz3d.com/wet-and-tanned-skins-for-genesis-81-females
(I got it by buying the whole bundle: https://www.daz3d.com/wet-and-tanned-skins-for-genesis-81-bundle )
Thanks. I have the wet and tan for G8. I can, maybe transfer to G9 or 8.1 via the Legacy UVs for Genesis 9: Genesis 3, 8, and 8.1 Female | Daz 3D or just use G8 ...experiemnts soon.
