Creating/Saving/Applying G9 Full Body Morph
I have a full body morph for a character I created for Genesis 9. But I'm not sure of the proper way of saving the OBJ file and then applying it as a full body morph.  Then I am going to create clothing that is appropriate for that character.
Genesis 9 has the body, eyelashes, tear, eyes, mouth and eyebrows as separate layers. So do I have to save the morph with all these different parts, or can I combine them all into a single OBJ file and apply that somehow?
First time I've made a character so I'm a bit confused. Help appreciated. 8-)
  • LeanaLeana Posts: 12,987
    You need to create the morph from the base figure alone (ie without mouth, lashes, and so on), and at base resolution, otherwise you'll get an error when loading the morph via morph loader.
  • DeeceyDeecey Posts: 173
    OK Thanks! That helps.
  • crosswindcrosswind Posts: 9,743
    You're not a PA anymore by now ? If you're still a PA, you have multi-resolution plugin then you can freely export / import OBJ with multi resolution ~~
