Scriipt IDE
Miss AnimatedMiss Animated Posts: 61
edited July 2025 in Daz Studio Discussion
Trying to create some Script IDE's.  this one is to simply go through every item and disable smoothing (where it exists) to make dForce physics to a bit faster.  Anyone see any reason why I cannot manipulate that value in here?  It refuses to change in the GUI despite running completely.  feel free to try this...(sorry formatting ripped out by editor so indenting is gone) . I highlighted the line in question (or I thought I did, it's line 75!)
Thanks for any eyes!!!
Post edited by Miss Animated on
  • Richard HaseltineRichard Haseltine Posts: 109,493
    edited July 2025
    The Script IDE is a pane for writing scripts - integrated development environment, I think. You are just creating scripts for Daz Studio.
    I  think you would do better if you added more error checking, and wrote the results to the log, so that you could see where it  was running into issues. That said, I have written a script to toggle smoothing on and off (which uses a marker on the node to decide what needs to be switched on) which you may find interesting to compare https://www.dropbox.com/scl/fi/kbwswqsowuhsb8ymthirv/ToggleSmoothing.zip?rlkey=js7eg2mfjdwlpe4wi570we72o&dl=0
