Morph dials aren't showing up
Michele
I am having a problem with my morph dials not loading. If I loda a specicfic charactor the shaping tab will only show what morphs are currently loaded in that model but won't display all my othe morphs that I use to mix and match and make unique faces and body types.
Do they show under Actor in the Parameters pane?
No.
OK. But specific character presets do work? What happens if you click the lined button in the top corner of the pane and select Show Hidden Properties?
Nothing happened when I clicked on show hidden properties. I'm pretty sure the morph dials aren't a hidden thing though. I'm really confused as to what could be going on with the program.
What do you see when you inject a character that is working?
