Scripts Tab not working in DAZ 4.24
I checked to see if the Scripts tab would work on a laptop that had the minimum DAZ install. I downloaded and installed Code 66. The same situation, The Scripts tab lights, but nothing else. I have 2 desktops and a laptop all from ASUS. 2 totally different motherboards.This problem has been around for several months. I had thought the Tab had been disabled until I saw it used recently. My last build was with new drives and new motherboard, with 64gig of RAM The DAZ was a fresh install.
Please let me know what else you might need.
  • crosswindcrosswind Posts: 9,667
    I'm not sure but if you mean the menu item of Scripts, you have to Create Custom Action... to add scripts to the menu item of Scripts.
    709 x 1370 - 206K
