Solved - No manage tab in Simulation Settings
Hi,
when I opened Daz the "Manage" tab in the simulations settings disappeared in the 4.24 version of Daz3d. How can I get it back? Resetting the workspace did not help.
Post edited by artsinis.san on
  • crosswindcrosswind Posts: 9,544
    In DS, log in Daz Connect and keep DS opened for a while, appr, 5 ~ 10 minutes, so as to successfully verify your Premier membership. Close DS and relaunch it, go to: Help > About Installed plugins..., check if dForce Manager plugin is enabled.
    Then you should be able to find its Tab in Simulation Settings pane.
  • artsinis.sanartsinis.san Posts: 8
    That solved it, thanks ^^
