Looking for hair and outfit to match this drawing
in New Users
Hello all,
I was hoping some one might know of a best match of hair and outfit for the drawing provided.
Ideally it would be a perfect match; the hair would have the bun situated at the top of the head with the hair parted to the sides, a standard dress shirt underneath the blouse with the initial collar above the blouse's while buttoned up almost all the way with both items of clothing having a notched collar, and the skirt with slits on the legs. The only item I'm not to stringent on is the glasses, anything similar will suffice.
Any help would be greatly appreciated!
How about this hair? https://www.daz3d.com/dforce-hot-mess-hair-for-genesis-9
Else for the hair try to search for "updo".
that's pretty close! do you know one similar for g8? or is it just going to be the updo?
You can try to search for "updo", but I can't remember any other from top-of-mind.
For using a G9 hair on G8, load the hair unfitted and unparented, and then move it in position on the G8 character. As part of the process you can also scale it in X and Z. It is easiest done if you hide the hair so you only have the haircap. When good parent it to the head of the character.
Best done in default A pose.
When done you can save it as a wearable preset, so it will load in the right place if you want to use it another time.
A few hairdos for G8 which might work:
https://www.daz3d.com/magical-arts-updo-hairstyle-for-genesis-81-females
https://www.daz3d.com/mega-updo-2-hair-for-genesis-8-and-81-females
https://www.daz3d.com/mega-updo-hair-for-genesis-3-and-8-females
https://www.daz3d.com/4-in-1-buns-and-ponytail-hair-for-genesis-8-and-81-females
Regarding the outfit, the closest I've found is this one for G9: https://www.daz3d.com/dforce-womens-office-outfit-for-genesis-9
For G8F here are a few products which could work to get something similar:
https://www.daz3d.com/formal-mega-wardrobe-for-genesis-8-females
https://www.daz3d.com/businesswoman-outfit-set-for-genesis-8-and-81-females (shirt is open too low but maybe you could morph it closed)
https://www.daz3d.com/fg-dforce-professional-suit-for-genesis-8-females
https://www.daz3d.com/hc-business-suit-a-for-genesis-8-females
https://www.daz3d.com/hc-dforce-office-outfit-for-genesis-8-females
https://www.daz3d.com/dforce-aisa-style-outfit-for-genesis-8-and-81-females
https://www.daz3d.com/dforce-office-lady-suit-for-genesis-8-and-81-females
Much appreciated! Those are some solid options, some which are really close. I'll try to see what I could make work
