DAZ not using RTX 5090
Hi guys. I need help. Just bought a new computer for rendering work. SPECS: Windows 10, GPU RTX 5090, RAM 128GB, Processor i9 14900K   3.20 GHz. (this is desktop computer)
When rendering, DAZ is not using the GPU. I have unchecked the CPU (both), unchecked Allow CPU fallback on Hardware setting. I have also installed the latest driver for NVIDIA - version 576.40 (12 May 2025)
Also have turned ON hardware accelerated GPU sceduling.
However render result is simply black screen. Even rendering a simple ball with no background at all doesn't work. I'm simply getting black screen. I am frustrated having tried everything I know. GPU-Z records 0% usage on the GPU.
Perhaps I'm missing something? Any other suggestions?
  • The 50xx series is only supported with the Alpha.
    Are you using that?
  • roland58roland58 Posts: 14
    Same for me.
    How is it possible?
    Any solution?
  • roland58 said:
    Any solution?
    To reiterate my previous post, the 50 Series are only supported in the alpha branch of studio releases.
  • ThatOminThatOmin Posts: 43
    roland58 said:
    Any solution?
    Use the graphics card you had installed before.
    I have a 5090, but use my 3080 TI for Daz Studio.
  • MasterstrokeMasterstroke Posts: 2,304
    roland58 said:
    Any solution?
    Install the Alpha and use that for final rendering.
    (alpha and General release work side by side)
  • This is unacceptable. I levereged myself to create my current build and I have to use Alpha? What if I want to render a queue of images? Manfriday's Render Queue will not run on alpha.
  • Richard HaseltineRichard Haseltine Posts: 107,973
    A script could do basic batch rendering, but at the moment the only option for an off-the-shelf aproach would be a Premier mebertship I am afraid.
