about HD morphs again
Masterstroke
in The Commons
I've purchased a character with a full body HD morph. Too bad, that part of that HD morph are big poking nipples, that I would like to get rid of.
Anything else look perfect, though.
So how do get rid of those HD nipples?
Depends upon how they are made.
The first thing to check would be the Parameter Tab, look for nipple morphs to dial down. {select the area on the figure, might have to enable 'show hidden' on the Parameters Tab}.
You can remove the limits on the official Nipples and Areola morphs and set them to a negative value, in order to try to negate the influence of the hd morph (it worked on Genesis 8 when I had the same problem).
Another solution: you can do a full render with the HD Morph active and then do spot renders with the HD morph inactive before merging them with the full render in your favorite image editing software.
A possible third solution (I'm not sure it can work on HD Morphs) is to favorite the hd morph, to then switch to the geometry editor, then select the geometry around the nipples, convert the selection to vertices then right click in the viewport to tell Daz to remove the selected vertices from favorite morphs.
Yeah, good idea, but none of the HD nipple morphs work against the full body HD morph.
Okay then. Look for the 'name' [not label] of the HD nipple morph. [Parameters Tab, edit mode, see what it says]
Close D/S.
Open up the data folders and look for said morph. {somewhere under Daz3D > Genesis Number > etc ... morphs > creator's name likely > and all HD morphs are clearly identified as such, remove from the folder the one{s} for the nipples. Close the folder.
Open D/S, load character ... hopefully she'll now load as desired. You may [or not] get an error message to ignore. To stop getting error messages about missing morphs requires some file editing.
I am sorry, but there is obviously a misunderstanding. The nipples are part of a full body HD morph. As you've suggested, I've tried to find a HD nipple morph to counterpart the full body morph, but it didn't work.
I didn't even expected to work, because that would have been a rare coincidence. Worth trying though.
That is the problem, when content creators overdo it with HD modelling. Instead of only adding details, they add bigger structures into the mesh. In this case poking nipples.
I need to get rid of the poking nipples from the full body HD morph.
Sadly that's not something we can do. Sometimes PAs provide an option to turn off Nipples, etc. [would be located in the characters folders which I find in the Content Library].
Any chance that another morph for the nipples to flatten them would work?
I suppose I'm in the two other participants ignore list
, because:
1. the first solution does work on Genesis 8 (I used it on this render and this one),
2. the second one will work with any generation (and is likely the fastest: I initially try the first one because I may not have known at the time that a Spot Render could done in a new window and then merged on top of a full render),
3. the third did work on Genesis 8 when I tested it a minute or two ago (no idea if it'll be saved into the scene file, I already have a proper solution for both scenes).
Regarding the first solution, here the situation with the HD morph dialed in at 100%:
Then after having removed the limit on Nipples and Areolae Depth and set them to negative value, the breastplate is not impacted anymore:
