G3F loading with some shape morphs dialed up
TheKDTheKD Posts: 2,711
When I load up G3F default figure, she doesn't come in as default anymore. How can I manually fix that?
  • TSasha SmithTSasha Smith Posts: 27,323
    Do you know which morphs are being loaded dialed up?
  • TheKDTheKD Posts: 2,711
    Not a clue. Any quick way to find nonzero morphs? Not a studio whiz by any means lol.
    Go to the Parameters pane, and check under Currently Used.
    If there are morphs loaded there, then zero them, and resave the figure.   That is the quickest way I know of.
    edited October 2015
    Ok finally found the culprit morphs, zeroed it out. Which save do I do?
    Post edited by TheKD on
  • DarkSpartanDarkSpartan Posts: 1,096
    Save Modified assets under Support Assets, IIRC. I have a render running so I can't check. It'll give you a list. Also, for the default G3F, Mouth Realism HD and Navel are both dialed to full.
    I was able to have my girl download and email me an update for the product that had the dials up, that fixed it. Glad I didn't have to wait untill I fly home in almost 3 weeks to get it sorted out lol.
    In case anyone does a forum search to solve the same problem, the offending item for me was a character named abbie :D
