Undo/Redo Buttons disappeared
Imagine my surprise when I opened Daz Studio about an hour ago and found that the Edit/Redo buttons that were in the upper left hand corner of my workspace had mysteriously disappeared. They used to be right above the Products and stuff is in the attached screenshot. I can still use the Undo/Redo things in the Edit tab, but it's way more conviennt if those would come back.
How do I fix this? Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,672
    Try reloading your layout (Window>Workspace>Select Layout) or just make sure the tollbars you need are enabled in Window>Workspace>Customise in the Activiities tab on the right.
  • Thanks, I somehow figured it out about half an hour or so after I made the post.
  • Alowe49Alowe49 Posts: 42
    I find control X and control Z easier - old school
