Please recommend me some good "Thicc" Models (with Thigh CBS/JCMs) for Genesis 8.1
Most G8.1 models have realistic proportions so they need no thigh CBS/JCMs. Can someone recommend good models with thick thighs (must have CBS/JCMs for said thighs). I have so far only got G9 figures with such details. Most notably from creator - Pendragon (https://www.daz3d.com/pendragon)
Few reference models are -
PN Una for Genesis 9 - (https://www.daz3d.com/pn-una-for-genesis-9)
PN Ana for Genesis 9 - (https://www.daz3d.com/pn-ana-for-genesis-9)
Most of my G8.1 models have this distortion (Image attached below) when thighs are 85 degrees. So I need models with CBS/JCMs which do that automatically.
At last my clarification for "Thicc" - Thin waist, wide thighs
Thanks in advanced.
Post edited by Loki_Thundrell on
I don't know of any models like you are looking for here. The closest I know of would be Cyberean Character and Bodysuit for Genesis 8 Female, but she would need some additional morphs to get exactly what you are looking for. The creator of the Cyberean character now sells at RenderHub. I also have Jamile For Genesis 8 Female from the same vendor (Marcius) and she is much closer to what you are looking for. Both Cyberean and Jamile are ver good quality characters. Take a look at what Marcius has to offer at RenderHub, you might find what you are looking for. There are also a couple of vendors at Renderosity that make characters with similar features.
Cyberean (sold here) can get very close to what you are looking for with a few additional morphs (example here: https://www.deviantart.com/dust-rider/art/Cyberean-773534129, but I don't know more extreme morphing will cause the issue you have noted with bending.
Hopefully someone else will pop in and give a few additional possibilities.
Thanks for your reply. The characters you recommended were very good, but sadly only G8 and aren't thick (wider hips) enough. So they don't require a thigh 90 degree JCM on the thigh.
As for the extreme morphing, its just a default 85 degree side-side (Image attached below).
I have checked out many vendors (a lot of them very popular), and mostly for G8 and G8.1 characters the thigh_side-side jcm is not present, even when they are needed. Which is a little disappointing because in poses like a kick or a yoga pose they make these bad deformations. So I have to manually make JCMs for them which is a hassle even after paying money. On the other hand some models are filled with JCMs to give great deformations. So if someone can provide me with a good vendor for G8.1 who makes thicc and a little stylized characters I will be grateful. Meanwhile I continue my search.
Opps!! Sorry, I missed that you only wanted G8.1. Yes, they are hard to find. I found a couple at RenderHub that may work. I haven't bought anything there, or from either of these vendors. but they are on sale right now so it may be worth trying one out if you like either of them. I don't think RenderHub has as good of a refund policy as DAZ, but if you really like one it might be worth trying. They are:
FRND Taya for Genesis 8 and 8.1 Female
Edit: I liked AB Diah so I thought I would give her a try since I've never bought anything from Render Hub. While she generally seems to be very well done, she does fail when tested for your needs. - AB Diah for Genesis 8 and 8.1 Female
I also found one at Renderosity that you might be interested in:
Cati For Genesis 8/8.1
I forgot to mention that at Renderosity and RenderHub you can contact the vendors directly so you could ask if the models have corrective morphs that address the issues you are having. I've "heard" that some vendors are less responsive than others, but it might be worth the effort if they do respond and have implemented the needed corrective morphs.
