Text-Based Way of Changing Textures
Write Idea
in The Commons
Extremely odd question, but is there a text based way to change out textures? I find it so tedious to go into the surface panel and manually changing all the texture files, rummaging through the folders, etc.
I have a very uniformed way of naming all of my textures, and it'd be SO much simplier changing via typing it out rather than manually clicking everything.
You can make a script.
But how do you imagine it should happen?
my biggest gripe is that diffuse/albedo, roughness and normal are not next to each other in the surface list and the texture arrow not big enough to easily drag and drop them in from an open explorer window
( I do this anyway but the user interface is so tiny and twiddly)
I guess one could create a shader preset with everything else hidden
there are things like fabricator (in my wishlist) that are supposed to ssomewhat address this
(if you only have a base texture)
https://www.daz3d.com/the-fabricator sadly pre iray
Example: I want to make two characters. One named Bob and the other named John. I manually do all the work needed to set up a preset for Bob. Bob's files are titled like BOB_HEAD_DIFFUSE.PNG, BOB_HEAD_SSS.PNG, BOB_HEAD_SATURATION.PNG, etc. All the files are located in the Bob folder (C:\DAZ3D\Textures\Bob\). I save the preset. Bob's all good to go.
Now I need to make a preset for John. They are identical settings, except different texture names. In order to make a preset for John, I have to go into the surface panel and rummage around to find all of John's textures. Very time consuming.
All of my files are named in a similar pattern. If there was a text based way of changing the location of the files, it'd make it some much simpler. Because I need to swap out over twenty-something files over multiple character. If I replace the BOB_HEAD_DIFFUSE.PNG for the JOHN_HEAD_DIFFUSE.PNG, all I'd have to do is search, copy, then paste.
Base Color Location: C:\DAZ3D\Textures\Bob\BOB_HEAD_DIFFUSE.PNG
...to...
Base Color Location: C:\DAZ3D\Textures\John\JOHN_HEAD_DIFFUSE.PNG
Hopefully this makes it a bit clearer?
LOL, I edited my comment and we crossposted
Smart content DOESN'T work for me, Microsux deletes PostGreSql on this PC no matter how much I delve into my security, firewall settings (Googled search everything to no avail)
so I absolutely cannot help you there or test how it's supposed to work
hence I deleted that bit
I'm no good at scripting, so personally I'd do it in a text editor.
1) Setup "Bob" as required and save as a materials preset
2) Duplicate that material preset file and rename it "John".
3) Use Notepad++ (or similar text editor) and replace instances of "Bob" with "John" then save
4) Load the "John" materials preset, check he looks right then save him as a Character preset or a Scene subset or whatever you would normally do.
Lol, two ships in the night!
Sadly when I open a DUF file in a text based editor, it just comes up garbled. Nothing is readable. I just get random symbols. And I saved the DUF file both compressed and not compressed.
I don't have Notepad++, so I can't be for certain.
That's odd for a preset you saved yourself (and saved uncompressed). Try "unzipping" it - I use 7-Zip - and see if it's legible then (it should be). Alternatively I think Daz Studio has a script utility inbuilt that can uncompress and put into clear text - I can't remember eactly where, I guess it's in Window-Tabs menu?
Notepad++ is free to download and (IMHO) indispensible. It maintains the line breaks and formatting which something like ordinary Notepad does not. It's all too easy to corrupt a .duf file using basic Notepad.
Notepad++ worked like a charm!
Readable and editable!
Thank you, @MelanieL!
Defender? Does Exclusion not work?
I have read every thread here on the topic
Win10
it does work on my Win7 machine but I barely use that, certainly not for DAZ studio as no graphics card
it started after my C drive failed and had to be replaced
I have no idea why it removes it but it does or what removes it, Windows Antivirus shouldn't be as whitelisted it
I don't have any third party AV
I don't want to derail this thread but posted many times on this forum about it over the past couple of years, at this point just saving for a decent Win11 machine with a better GPU instead, hoopefully next year
this one not worth updating to Win 11, no TPM and is not a great PC
intend to just keep it for Carrara Octane as will not be able to run it on newer tech without a subscription
OK, strange. If you reinstalled Windows on the new disk (instead of restoring the old system from image/backup) my guess would be Defender didn't install correctly, so exclude/whitelist doesn't work. I've seen such glitches happen a few times where certain things don't work as they should on a new install. Running a Windows repair may work in some cases, but I imagine you have tried that.
But otherwise I have no ideas.
I had a shop do it, they DID clone my old drive, have a SSD now, but I had to reinstall all my programs, many random things no longer work though
including the DAZ to Unreal exporter, I cannot be bothered quite frankly not reinstalled many things
I manage OK generally, loads much quicker without smart content
