Wrist and hip posing weirdness G8F&M
N-RArts
in The Commons
I know I have seen others posting about this before. But I couldn't remember possible solutions.
This is on custom morphs for Genesis 8 male, and female. I've checked JCMs. They don't make the situation any better... Just worse.
Sometimes this comes from either HD morphs baked into the mesh, displacement or normal maps, but most likely, if it is the custom morph, causing this.
One rule, everybody ignores. custom shapes need custom JCMs.
Create your custom JCM set controlled by your custom character morph dial.
Have you adjusted rigging to shape?
I'd suggest that the elbow shape is right for an older person without too much bicep muscle - my bedbound MIL shows exactly that (only more pronounced) at the moment. The hip is, as you say, a bit odd.
Regards,
Richard
It doesn't look like a missing rigging to shape, although worth checking.
Rigging to shape is importand, but never enough.
The more a custum character's shape differ from the base female, the more an additional set of JCMs is required.
Adjusted rigging to shape was the first thing that I do (especially after creating the morph)
There might be a HD morph in there somewhere. I ERC freezed everything, so I have no idea.
I've got my new computer up and running now. So I might give her character another try (without a HD morph).
However, I'm guessing that there may be a possibility that the same issue may have been copied over to G9?
