normal pose for gen 9 actors?
dondrawdondraw Posts: 170
i posed my actor in a nice pose but when i tri to fit hair on, it always misfits, so i suspect actor needs to go into a neutral or natural or zero pose? in order to apply hair correctly. Right? what should i do to make this work?
  • dondraw Usually I pose any character in the default pose, this can be like a T pose Gen 8 or something similar in Gen 9
    The hair should have an auto-follow function
    First highlight the character, then find the type of hair you like, apply it over the charaacter.
  • dondrawdondraw Posts: 170
    Hair continues to be a problem. This actor is id'd as being gen 9, and i search for hair with Filter by Content shecked, and Toulouse Hair pops up and seems perfect for this character, but I select and attach it and when I more character I realize it's not really attached!!
    Advice please!
    drawn
    692 x 1128 - 512K
    692 x 1124 - 509K
  • felisfelis Posts: 6,105
    edited June 2025
    If you use it on base G9, does it then follow?
    And which Toulouse hair? I thought it was the one from starter essentials, but that is named Pixie for G9.
    Post edited by felis on
    ok, i found a hair that does fit, so drop this quert please.
    don
