How To Apply Materials To Shoe Prop
3DSaga3DSaga Posts: 751
I have these shoes: https://www.daz3d.com/rina-wedge-high-heel-shoes-for-genesis-9-and-8-female. When used as wearables, applying the optional materials is straightforward. One reason I like this PA's products is they provide the option to use the shoes as props. What I would like to do is apply the optional materials to the shoes when they're used as pops. When I try to do that, I get an error message (which I haven't been able to find in the lengthy log).
When I look at the shoes in the Surfaces pane, both as wearables or as props, the Base Color is shown as white with <?>. Does this have anything to do with the issue? Is it possible to apply the materials to the props?
  • zombietaggerungzombietaggerung Posts: 3,873
    They are probably hierarchal presets which means that the shoes HAVE to be parented to the correct figure in order for the materials to work.
  • 3DSaga3DSaga Posts: 751
    Does this mean that the prop version of the shoes are not able to be used with the materials (i.e. only the default material)?
  • Matt_CastleMatt_Castle Posts: 3,093
    Not directly from the presets, but while it's a little more tedious, you should be able to copy surface parameters of a with version to the prop version. Potentially worth a customer support ticket though if something in a set isn't taking materials properly.
