Blank render driving me insane
I tried all of my usual fixes (reducing line tesselation in strand-based hair, ditching strand-based hair, removing literally everything that doesn't appear in the shot, shutting down and restarting fresh), and so far all for naught [my render is still blank].
It's a simple scene with only one Genesis 9 figure. It should not be this hard.
I'm running Windows 11 with 32 GB RAM, GPU is an Nvidia GeForce RTX 2060 with 576.52 Studio drivers.
Here's the log file for the crash:
2025-06-12 11:40:54.097 Iray [INFO] - IRAY:RENDER ::   1.18  IRAY   rend info : JIT-linking wavefront kernel in 307.477 ms2025-06-12 11:40:54.111 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 2060): Scene processed in 12.393s2025-06-12 11:40:54.112 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 2060): Not enough memory for kernel launches (220.254 MiB (out of 220.254 MiB total) still required, 0 B available). Cannot allocate framebuffer.2025-06-12 11:40:54.113 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 2060): Failed to setup device frame buffer2025-06-12 11:40:54.113 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 2060): Device failed while rendering2025-06-12 11:40:54.113 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [WARNING] - IRAY:RENDER ::   1.5   IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 2060) ran out of memory and is temporarily unavailable for rendering.2025-06-12 11:40:54.621 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [WARNING] - IRAY:RENDER ::   1.5   IRAY   rend warn : All available GPUs failed.2025-06-12 11:40:54.621 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: Fallback to CPU not allowed.2025-06-12 11:40:54.621 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: All workers failed: aborting render2025-06-12 11:40:54.621 [ERROR] Iray :: Internal rendering error.2025-06-12 11:40:54.717 [INFO] :: Saved image: C:\Users\abelu\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png2025-06-12 11:40:54.717 [INFO] :: Finished rendering.2025-06-12 11:40:54.760 [INFO] :: Total Rendering Time: 34.96 seconds2025-06-12 11:41:03.946 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:2025-06-12 11:41:03.946 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 2060): 0 iterations, 12.717s init, 0.509s render2025-06-12 11:41:06.970 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:2025-06-12 11:41:06.970 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 2060): 268 iterations, 2.378s init, 6.591s render
Thanks in advance for any advice!
  • felisfelis Posts: 6,042
    In short.
    You are running out of VRAM, and CPU fallback not allowed, so nothing.
    Which subD has character or clothing?
