How do I move multiple objects at once?
krishunt_de3e77f5ee
I have three objects that I would like to rotate 180° as a group in Daz Studio 4.8. Seems simple enough, but I can't figure out how to do it. "Select All" seems to select everything, but when I then try to rotate everything, only one of the objects rotates.
Post edited by krishunt_de3e77f5ee on
you can create a null from the create menu. attach all the items to the null and rotate the null.
Or you can select the items and make a group.
There are soem differences between how groups and nulls work. If you turn off a null, the items parented to it stay active. It works the opposite for groups.(and some other differences) But for your case both options should work.
I just realized that when I selected all, I also selected my camera, which I want to stay put. How do I select multiple objects one at a time? I would think you would hold down Shift while clicking, but I guess not.
Hold down the control or cmd key while selecting them in the Scene tab.
Thanks.
I'm a bit new to Daz - considering I've worked with Qavimator and tabbed into 3D Maya (a bit) things come a bit naturally except.. I do not know how to select both a Male and Female mesh to move them up/down, back/fort and etc. Is there a command to select both? I've tried selecting the female pelvis and then hold the shift key to select the male's pelvis.. that did not work. If anyone can help, much graditude.
