I Really Need a File Folder that will Open and Close
Fauvist
[I Really Need a File Folder that will Open and Close] Just a plain office file folder, the type you keep in a filing cabinet. I need to be able to open and close it. I have a lot of file folders that you can't open or close.
Thanks!
If you can't fine an articulated one, I think you could use geometry editor to delete the back and save the front as a scene subset. Then do the same with the other half. Merge them both into a scene and parent one to the other... not elegant, but in theory ought to work so now you can rotate one and it will open?
This set has one, but I'm not sure if it's the type you're looking for:
https://www.daz3d.com/interiors-the-classroom
I knew I had one...it's rigged and in this set along with a bunch of other rigged and morphing props. https://www.daz3d.com/professors-office
